mopar-mike's 71 duster project
mopar-mike
Active Member
missouri
okay i have a few pictures and yes i am going to post them. no "this thread is useless without pictures" lines need to get used here. i will do my best to explain what i am doin any questions just ask...oh yeah...my punctuation sucks..lol
okay having trouble uploading files:angry5: i will try again tomorrow when i come in from working on it, plus i will have a bunch more pictures anyway.
sorry guys
here are a few pictures of the car when i brought it home. this is the way i bought it, lots of work to do i know.
after hours of messing with the timing and changing out the points me and a buddy finally broke down and pulled the timing cover off. the timing chain was crazy loose and the cam sprocket had a couple of missing teeth. both sprockets were that plastic junk, which if i am not mistaken is what they used in the factory. we replaced both sprockets and the chain with a double roller setup and steel sprockets. got everything assembled and timed out best we could but when number one piston was at top dead center the rotorbug was pointing at number two cyl. turned out the distributor gear had jumped a couple of teeth, jumping it back was a major pain in the a$$! when i cranked it over it fired right up, thought that was pretty cool.
got me a donor car for the disc brake and big bolt pattern swap, it is a 74 dart swinger slant six auto. i will post a picture. i think i will steal some of the interior out of it as well, the back seat is perfect and so is the dash pad.
here are a couple of pictures of the driver side spindle and upper control arm while it was still on the swinger.
a few pictures of the cleaning up of the caliper mount, and then one of the mount and caliper together with pads in as well.
no that is not a crack in that left bolt hole, it is a string to a tag that says driver that way i wouldn't mix them up.lol
lower control arm pass. side of duster, right before i put upper control arm, spindle, rotor and caliper assembly on.
i am gettin ready to put a pic up of the upper control arm, spindle, rotor, caliper and pads installed. you will notice that there is no longer grass and gravel under the car. this is because i forgot to take the pic after i got it done, i was too excited to throw some wheels back on it and get it over to my buddies shop, where i remembered to take a pic.lol
here is the pass. side of duster everything from the dart cleaned up and installed. i went ahead and replaced the rotors, calipers, pads, bushings, wheel bearings and hose with new. figured had it down this far why not. but the upper control arm i blasted and painted, the caliper mount and spindle got the same treatment.
i dont have any pictures of the original seven and a quarter rear. guess i am pretty bad about takin pictures sometimes.lol here are some pics of the installation of the eight and three quarter. oh and also some pics of the drum clean up. i know it didnt serve a purpose but it made them look a lil prettier.:thumblef:
didnt feel like leaning over the blast cabinet today so i just wire wheeled these, i think they turned out okay.
here it is with original 7.25 removed then bolting u bolts up on the 8.75, the guys in the pics are a couple of good friends of mine. gotta love the help from friends. then the last pic is rear in, one of my buddies is still under there.lol
i know them quarters look horrible!!! lol i am going to put whole quarter replacements on this fall, plan on doing all metal work over the winter. for now i jus want to get it so i can drive it around and enjoy it a bit.
blew a freeze plug out, friend of mine said it was prolly already loose and with it sittin for so long before i got it and then us startin it up it prolly made it pop out. :sad: that is why i was so excited to get it on trailer and over to friend of mines shop, so we could pull motor and trans and check everything out.
here we are at buddy's shop, already pulled hood off and yanked radiator out. after that we called it a day because we put both the front and rear ends together before we could put it on trailer. i was pretty tuckered out after all that:sleepy5:.lol
wait a minute, just noticed that the radiator is still in in this pic. it must have been right after i took this pic that i pulled the radiator.
