Mopar Performance Distributor adjustable advance?
No. The factory Mopar style has an entirely different mechanical advance. It's non adjustable.
I realize that. My question was whether the same slot length in the MP Mallory units and factory units (after welding and filing) results in the same amount of advance.
You guys make me want to cry. Why? Because people assume that everyone understands what they are talking about. I am not an electrical engineer, or distributor guru, or carburetor airbleed tip in guru either. I have FBO parts in 2 cars, one is running fine with them. The other one isn't together yet, but has the FBO distributor and module. All came recommended from a respected engine builder that occasionally makes comments on this site. Sometimes I feel like I am back in the Army, and my poncho fell apart on a forced march and now I am on the side doing push-ups for embarrassment, so that it doesn't happen again! I have no idea what those red gauges do yet, I have a set, they came with the new distributor. Just haven't gotten that far. Maybe Red Green can help me with some duct tape! I will keep watching, we're all in this together.
Just ask whatever you ain't gettin and we'll do our bestest to help you understand. The red keys for example. Each one is a different thickness. You loosen the advance screw on the breaker plate on those distributors and use the keys to stick in the slot to give you "whatever" advance you're looking for. The length of that slot controls how much advance you get. Bigger slot = more advance.
Oh ok. Now THAT I don't know, but I would just bet not, since they are completely different designs.
Any time you need help with this stuff, the call is free, LOL
Do you guys know if that chart above works for both the adjustable MP distributors AND the old factory units? I've always wondered that.
The weld it up slot lengths for the winged plates on old style/OEM are different
Okay! I have your number, somewhere. When I get to the Hemi dist, I will ask.
Thank you guys!
Thank you for all your replies! I was already looking for a new distributor not knowing that the one I had was actually a really good one.
No, it's not trial and error. Get a grammar school protractor. Stick the rotor on. Put the protractor above the rotor so the tip or the rotor is pointing to zero. Now, twist the rotor advanced and see how many degrees you have. Multiply that times 2 and you have crankshaft degrees. So if you have 5 degrees at the distributor, that's 10 crank degrees. Get it? Screw that trial and error chit. And screw that FBO guy. lol
Thank you, I always appreciate learning how it's done correctly!
I did find the tuning keys on ebay and they even come with springs. I also ordered a new reluctor because the one in the distributor is pretty chewed up.
You're certainly welcome and remember, if you get hung up on something, don't be bashful. Just ask. We can walk you right through it.
Just the non adjustable ones with a fixed slot on the advance cam
You will likely not be able to buy springs to control that advance mechanism. You can’t get a spring that is stiff enough.
I had new weights made just for these distributors so that I can do some testing and see if i can change the weight and shape of the weights to get a better curve.
Depending on your engine you may be able to get a reasonable curve with what you have.
I got one of those FBO limiter plates and was about to set it in the distributor, when I noticed two things. At first I noticed that the reluctor was a bit unevenly worn and the pick-up wasn't parallel to it. I'm sure that can't be good.
AP1GczMMgaiDzXNg4_TduK57QJIz2MU6sI7T_lcoofd_piA8qxgzTLyaAdfew9U7bTvoRZmdFERvZUomTQwHVwP_clWZ7oCmGGD-YrqtwrXNDkDJy7Kp55f85R5qI8SYmgbJhg8T1uDLt3FLP_Faakb-9OaHLA=w791-h1054-s-no-gm
Upon closer inspection it looks like the plate is bent. I think I can bend that back.
AP1GczMvRnmGiJAjeBg-HR6I_5hy71s2uS-tYC1KHFNSZRfohfwmNx0gQnXKrEkqAiV9npat7I2pGFEjXlJBjV_nKQLeuOhUI57fidBLKs7jTLD74o0balDS3DBDOk0jfwilkuLqiMIuJdPm9NIc44we2XI1Jw=w1405-h1054-s-no-gm
I noticed that the FBO limiter plate is not going to work, but that the adjustment can be done with an allen wrench?! I don't know for sure that this is a Mopar Performance distributor and there is no part number on it, but when I looked at photos of MP distributors, they look just like it. Anyways, what I like about the FBO plate was that you could set your initial and then set total based on that number plus whatever added up to 34. My initial was 22, so I was going to use the #12 slot. I wish I had opened that distributor before I ordered the plate and the springs, which I don't think will work either. Anyways, any idea how I can set this up without having to take it out again 15 times?
AP1GczMDwmOuL3iO63BzOo1QyTOejRB5LBrqKKKG1vxxgSbF82hpyK1JEX4hh35uFPBYzUgcpqKt5gB1mWDgYer__qWPv_ORd2Zxgw_lMeMw7s6SsREs_W2_CLFVdA4T66yM2S1ulEwD11ph8-gVOyU66E-eGw=w791-h1054-s-no-gm
Someone commented that you should toss in the nearest garbage can. I'd add, buy an MSD distributor. They have the advance springs on top, instead of underneath. Setting your advance is a piece of cake.
