Mine was broken in just fine, only outer spring, the recomended lunati springs, all the lubes, has run good as mentioned. Did not expect this.I had two Micro Trols go bad. Called Lunati and the first thing they said was only two things will wipe out a cam lobe, not enough zddp and to much spring pressure. I told them I took out the inner spring and added a zinc additive. He said send it in and we will look at it. Im going to bet they say it was my fault. Oh well, it only cost $10 to send it to them. alot of people are getting bad lifters
Go to the speedtalk. com website. Look for the lifter thread dated June 29.
Lifter Manufactures And Who Are They - Don Terrill’s Speed-Talk Guess it`s this one.Can you post a link?
Yes they clearly states their lifters are US made .Weird website, does not state if it`s a set of 16 ,But it must be , right . For 190,75$ . Mopar high rev ones .Chrysler "Mopar" Made in the USA Hi- Rev Hydraulic LiftersClay Smith - has [USA] made [LA] hyd lifters, help support those remaining companies that actually care about preserving their reputation.
Give them a call u will reach a [HUMAN] who actually gives a **** and appreciates customers !Yes they clearly states their lifters are US made .Weird website, does not state if it`s a set of 16 ,But it must be , right . For 190,75$ . Mopar high rev ones .Chrysler "Mopar" Made in the USA Hi- Rev Hydraulic Lifters
So, now they are all out. Not two of them has the same wear pattern. Five can be thought OK. Others pitted, one severely, guess that one the next to fail. I have taken apart old used junkers with better ones.
The top right one is gray of pitting. Tomorrow the cam comes out. The wiped one is bottom third right .
What's so bad is we still pay high prices for offshore junk ## And we allow or let those Corporations screw us
Oh and the wiped one is missing 0.040 of material + the bowl in itThe top right one is gray of pitting. Tomorrow the cam comes out.
It`s almost like it`s on purpose, trying to get us to buy even more high $ rollers. Should be a class actionWhat's so bad is we still pay high prices for offshore junk ## And we allow or let those Corporations screw us
I just got a mail reply from Mellings technical services manager. Their lifters are made in either a facility in North America or Mexico by an "OEM tier supplier and are of OEM Quality, not the overseas lifters you are hearing horror stories about" end of quote. Well, thats reassuring i think. They have a #290114 hi - rev lifter. Might be worth a try.
Makes me wonder if a set of those and, if someone makes any worth a darn, a set of factory type 1.6 rockers would add any "oomph" to a .484 purple cam?Give them a call u will reach a [HUMAN] who actually gives a **** and appreciates customers !
