DionR
Plenty of people have bolted Magnum heads on their early blocks, with virtually no problems (with the right lifters and pushrods). I should have known better than to think it would work that well for me.
I ***umed that because the factory heads bolted on fine, the aftermarket MP cast iron R/T heads would also.
Picked up what I thought was a good set for a reasonable price to make the conversion about a year ago. Decided in December to get them checked just to make sure they were ok, ended up that 4 of the valves were bent because the guides had been knurled and the stems seized in the heads. $280 and (4) new valves later, I have a good set of heads. That should have been my first clue this wasn't going to go well.
Set one of them on the motor yesterday, and dropped a couple of pushrods in to check the length of the MP conversion pushrods. Length checked out ok, but the heads don't have sufficent clearance for the pushrods (top or bottom).
I'd heard rumors about it, but hadn't seen it before, so I wasn't entirely surprised. Doesn't look like something that you can fix with a drill bit, either.
In addition to that, the exhaust flange doesn't have sufficent material around the port on the bottom to seal to the manifold and allow me to run the 340 freeflows I had on the car.
If I spring for the roller lifters and cam, I can avoid the pushrod problem, but I'm not sure what to do about the exhaust. I could run a right side Jeep mainfold, but the left needs to be the A-Body specific one.
My buddy had a set of production magnum heads, so set one of those on the block, and neither of these issues exists with those heads. Just the MP R/T heads. Figures.
Just figured I would share, in case I saved someone else the same grief.
Anyone want a set of 1.92/1.625 cast iron R/T heads, ready to run? Only $700 plus shipping. ;-)
