Mopar R1 block
I would think un shrouding the valve a win win. Those w5 heads we have need a big bore and stroke to work.
If you have the material why wouldn’t you?
Forgive the upcoming AJ length post....
Answering the question first, I gave the answer above. How far you want to take it is your (or machinists) call.
Wyrmrider made a good mention about cylinder wall flex. I didn’t think about that comparison.
Now, about un shrouding the valves. Yes, it’s a win win for what ever head your have on top.
And no on what makes a W5 head work best is no different than any other head in general because of not what the head is but how a head responds to the available space around it.
Now just to touch on some science.....
The bigger the bore, the more potential the head can flow. Increasing the stroke also helps this. A cylinder head can only flow so much. When you reach this limitation, power falls off in the upper rpm range. This is dependent of the bore and stroke as well as the overall CID of the engine. What or where this limitation is has been discussed and reasonably solved with knowing the cylinder heads port size. (Cross sectional area) Over all shape and flow abilities are also coupled to this. But to back it up a minute and use the KISS method, the port window is the key.
This is why myself and Yellow Rose like the W2/5 head over the Trick Flow heads. Even though the trick Flow has a 300 cfm rating, it is flowing that much through a smaller window. Let’s take this into our imagination a second and blow proportions out.
Using an analogy from Dave Freiberger, if you have a doorway that’s 36 inches wide, how many people can get through in a minute to fill the concert hall? Now what if you have a door way double the size?
The first smaller door can have people come in jogging at 300 feet per minute, the larger doorway can have people jogging at 280 feet per minute.
Who’s getting in more people through the doorway?
To continue on.....
The cylinder head can only more so much air. There is a limitation. Increasing the size of the gathering hall (the cylinder after the door way) for more people than the doorway can let in, is the same as putting a small doorway in on any hall. (Engine)
If the doors are open for only 1 minute, then the head isn’t big enough. (Head to small) Repeat this process over and over to fill the hall, it’s like filling multiple arenas.
RPM shortens the doorways ability to completely fill the area. This is why you have 318 heads on a 360 making a ton of torque down low and running out of breath up top.
Brett Miller whom had a hand in the new Edelbrock Victor head, engine masters build challenge engine limited the size of the engine to 376 - ish or so cubes as not to have the head run out of breath in a huge cylinder filling with the coupled high RPMs expected from the engine.
What he ended up with was a highly efficient engine at a smaller size. The RPMs were high and power was made all the way to the top of pull with a small duration cam.
The large doorways to fill the arena were always open enough to fill the arena completely. Even though they were open only for a short time.
A much larger engine would run out of breath earlier.
While it’s not a bad thing or way to go about it, you don’t need a huge engine to be combined with high rpm in order to make the head work. You should look to a balance to make it work great. And IMO, that 372 - W2 is an awesome combo you have that I am also working on. I think it is an excellent combo ready for a reasonable sized cam to tear up the tarmac, where ever that may be.
On my up coming W5, it will be a (I hope) huge stroker that peaks early in RPMs for less stress and a foundation for well prepped Victors later.
I do believe the W5 set up combo I’m working on is a 9 second capable mill. A very light Duster will be employed. And it shouldn’t have to turn RPMs like crazy in order to do it.
I hope I explained that well enough.
I have posted my W5 numbers here before on the big and small test size bores. 4.03 vs 4.180 equaled about a 14 cfm difference on the big lift end. What you can wring out of 14 cfm is also a very build dependent thing. Back to the KISS method and math on CFM flow and possible power to ba made is, CFM X’s 2 which equals 28 HP. On a race mill, you can go more by a fair margin. CFM X’s 3 is not unheard of. (42+ hp)
To continue on.....
I’d take a W5 blowing 300 before I’d take a Trickflow blowing 300 same as you guys probably would.
There kind of an anomaly
I saw some years ago blowing 340 running quick 8s and 16s
To continue on.....
Thx now even i get it :-)
well worth it
so are aj's
mine? I got no comments on my how to set rocker fulcrum position post (without cad)
So the machinist claims .185” or 3/16 is cylinder wall thickness is what he claims would be a minimum, more is better.
Same as my guy. Below the .185, he expresses concern. If it is less than that he recommends the engine only for grocery getting and laughs.
He says 4.100 is safe, and 4.125 with a little hard fill shouldn’t be a problem.
So 4.080-4.100 for starters I’m thinking?
12-13 to 1 compression if I decide to spray it should be fine.
Less overbore the better unless you need to have that magic CID number. I do like a big bore to help the heads breath that just a little bit better though.
Id love to be able to get a block for a 4.180 bore size.
so would everyone else
at least wider bore centers than those pesky sbc's
note that the AMC bore centers are the same as the Buick which comes stock with a 4.315 bore
and only .050 less than a BBM
Guys above are correct.
The W5 is actually a “small head” for a 4 inch crank motor. That was more cubes than it was designed to be run on
I campaigned 422 forever with W5 heads. It wasnt all out combo, but ran 9.80’s in a 3350 pound car with super stock springs
I shifted it at 7 and trapped about 7400. Nice heads, if you find a set with integrity that wont leak, or ultimately leak.
Its very easy to run 9’s in a A body with them. If my car had been 3000 pounds it would have run 9.40’s/50’s. This with shelf headers and a cam that had very modest lobes because i drove it around a lot.
Probably little more on the table more aggressive lobe
So a 440”-450” engine size isn’t a good idea? The stroke I was considering is 4.125-4.25
Maybe 4.00-4.100 has better geometry with those heads?
i wouldn't if it was me. If i had it to do all over would ideally run a big bore and a 3.79 stroke crank with a W5 head.
But 4 inch will work fine.
Think that's the short deck version. My 48* is 9.555 I'll have to watch that video later. Work and all. Lol
I’ve been casting a squinty eye in the direction of the victor heads lately. That block with those is a very attractive platform for a 370’ish inch build.
Mines a 380. Made 550 at 6400. Looks like they pulled it to 7400 and it was still making over 500. Thats with unported W2s. Still trying to get it in my car. Eventually
That makes sense. To make actual power at that RPM with that displacement would require some serious induction work.
Is 4.100 asking to much? Idk I’ve heard people have certain x blocks at 4.165 and would go 4.180
Or just leave it alone and take it from 4.040
Have never heard of an X block going further out than 4.125, and that is super pushing it. I had one at 4.100. Some of them won’t go anywhere near that even, without getting thin.
I wonder if I should install 4 bolt mains on this x block?
I’ve heard the 2 bolt caps are quite a bit stronger. I believe yellow rose mentioned that. Probably for piece of mind I should.
Don’t bother, the 2 blot caps are fine. I made over an honest 700 horse with an X block and W5 heads with zero issues.
4 bolt caps are way overrated.
