Mopar trucks. 65 to 95. post pics
A few I've saved off the web....
heres a couple, first one is my fathers 77 dodge custom 150
318 4 barrel with mild cam
727 with shift kit 3:55 rear end
long wheel base stepside
custom interior
second is mine
360 4 barrel with 9k km's from winneobago
complete off frame restoration
body not yet finished
going to be the light blue like the box
custom interior
second is mine
This is Sanford. He's got bits of 4 trucks now. Reg'd as a '78. One ton suspension, 360, 727, 4.10 dana 60s front and rear, NP205 transfer case. Interior/cab is '87, front frame is '87, rear frame is '76, nose and bed are '78. He plows, tows, makes dump runs, hauls wood through the woods, and generally helps around the farm.
One of the coolest and funniest vehicles I have ever owned!!!! Big block 4speed!!!! 76 D-100
Heres a pic. of my old '78 Warlock that I used to have. Sold it a couple years ago.
Like my Rams as well, the first one is my plow truck, 1977 factory "440", it's in pretty good shape other than it neewd floor boards which I have a doner cab already. The second is one of 4 crew cabs, a 1977, kind of beat and needs motor & floor boards, third is my 1980 crew cab, 360, 4 speed, very clean, all origional and NO, it doesn't need floorboards, then I just had to add my 01, 2500 Cummins H/O, 6 speed. Too many irons in the fire!
Finding any kind not rusted out is hard.Finding a short step side is eveb harder.I need a tail gate for my step side,been looking for 5 years now.
wish i would have known, i had a complete bed off of my 78 I gave a way to a guy. he put it on his jacked up 79 ford f 150. bed was in great shape as was wood floor. i just went a different way and put a 81 cab,clip and fleetside bed on is stead.
what did you use to lower the front? heat or cut the springs? been wanting to drop mine alittle bit. i am sure the rear has axle flipped or coil overs and linked?
thanks
thanks
The front springs wear cut, and the rear axle was flipped, and rear wheel wells widened.
Man am I glad I found this old thread and got it re-started. Lots of great trucks out there. I figured most of us had trucks besides our A-Bodies. I have a "Before and After" thread here in Mopar General Discussions that may be back a page, but once I get my 71, D100 cleaned up and have new tires on her, I'll be posting her there as well.
Got my new Year-One catalog today and between it and the PST catalog, I have some orders to send in with my tax refund!
Here is my 1967 Dodge WM300 Power Wagon IT has a 251 Spitfire flat head 6 with power steering radio dual power brake boosters and 10000 lb winch also the front windshield opens with a crank on the dash
69 d-100 i scrapped
47 im building from the ground up (started with just the cab, hood, grille shell, and 1 fender)
my 99 ram
uncles ram, 1987 shortbed with a 360 worked out to 415CI. ran 12.6 in October, first time at the track lol
these are older pics, trucks not quite finished here
Some trucks from salvage yards and the drag strip in my area. I'll have to dig up the pics of my dakota R/T and 93 D350 dually.
Alan
86 Ramcharger AW150, with 30 over 360 and 260/268 cam, loaded. I painted this a few years ago, its paint job is a 20 footer.
BTW if anyone has any center caps that might fit, let me know.
