Needing help wiring a voltage regulator into a new (to me) race car. It has a two wire field alternator (70 dart model alternator). The car has a 7al2 and a MSD power grid controller with delay box. Don't want to FK the system.
The two wire box? where did you connect the + field wire. Thanks.I'm running a complete MSD ignition system, 7AL2 and crank trigger. I have an OEM style solid state regulator on mine.
The only Ignition "On" I have in the engine bay would be the + side of the coil. I was worried about voltage greater than 12.5. Is that possible?OK well what regulator do you have? If you have the once popular Mopar race regulator, you wire it like a pre 70. In other words GROUND it, the ign lead goes to switched 12V AKA key, "ignition run" and the field lead goes to either field connection on the alternator. Ground the remaining field connector
This one below
If you have the "flat" electronic one built for 70/ later, and they make (d) a race version of that also, you wire the middle terminal of the VR to switched ignition, the far right terminal to either field terminal and of course ground the VR.
Last, you take the remaining alternator field terminal and wire it to switched 12V
Like this
No no no not with MSD. If you are running a CD NOTHING and I mean NOTHING else should be connected to the coil except the two MSD box wires Not even the tachThe only Ignition "On" I have in the engine bay would be the + side of the coil. I was worried about voltage greater than 12.5. Is that possible?
thank you! That's what I was worried about!No no no not with MSD. If you are running a CD NOTHING and I mean NOTHING else should be connected to the coil except the two MSD box wires Not even the tach
Whatever you are using for a switch to get "run" power out into the engine bay is what I'm calling "run" or "switched 12V"
Is the alternator a Denso unit?I use one of the tiny Japanese Alternators that are 1/2
the size and more output.
I run a switch on the dash with a single wire to energize the
field. If we are running in Class and the race is close occasionally
we will shut it off in High gear. Once in Denver at the Nationals, I
won a headsUp race in E/SA by .0001 at the finish against Earl Blake
340 Cuda.
I am putting out 14.2 volts above 3000 RPM
even with a 5 inch pulley. the MSD does not mind at all.
Do you guys know that the old Mopar Perf. blue Regulator was "Constant
Charge"?
Generally yes, I have had great luck with them and they are relativeIs the alternator a Denso unit?
