273 Commando
mooser's dad
Ok guys, I scrubbed the motor and tore off the heads. I'm not sure what factory domed pistons actually look like but these pistons are definitely aftermarket slugs. They're flat top with 4 valve notches in 'em and stamped 060 on the piston face. Any ideas? I may as well pull the cam and have it profiled to see what it is too. The heads are '64-'65 with the 5/16 oddball intake bolts and the block is dated Dec. 65. Someone who put this together must've purchased a case of orange RTV because it's on everything including the freeze plugs.....dang! As I stated in my earlier post, the cylinder pressure was 160 psi, but I have no idea what the compression ratio is...any clues? Thanks, Ted
