younggun2.0
i have a 383 with the following parts assembled.
stock stroke 383 with forged crank
stock rods, resized, shoot peened/flash ground with arp bolts
speed pro replacement pistons. not sure of compression
eddy heads 84cc with mild port work
m1 single plane with 750 double pumper.
comp cams 525 lift cam
tti headers
727 with 4000 stall dynamic converter
cheetah manual valve body
aluminum drive line
8 3/4 with 4.10 and locker
28" drag radials.
as of now im guessing i most likely have 8.5-9:1 compression.
how much power would i gain if i were to take it back down and have some custom slugs put in it with say 10.5 comp.
tti headers
aluminum drive line
28" drag radials.
