More good news for the ford guys
pittsburghracer
Freeport, PA.
And their facebook reply about small block Mopars.
Ford windsor motors have always been hurtin for some good heads.
What does @pittsburghracer (or others) say about the intake/exhaust flow ratio (roughly 67%)? Maybe with that much intake flow that's ok?
I've always believed that in a NA engine, "ya can't eat if ya can't poop" so even though you have high pressure exhaust leaving, something in the 75% ratio ("more is better") is a good target.
I’ll add my two cents. If you remember about any of my porting posts I worry as per Darren Morgan’s suggestion to worry more about port speed than port flow. When shops give exhaust flow numbers some shops use a pipe, and some don’t. I’ve seen a pipe add 30cfm.
To a point as long as velocity is still high more is better.
