streetdak
So here is my dellima.... I love my Mopar stuff a ton, don't get me wrong, but its going to take some coin to get my dart to come close to as fast as my Camaro. For well under $2000 (that mostly went into my transmission) my 96 Lt1 Camaro was a reliable mid 12 second car. The only "internal" work I had done to it was 1.6 Crane roller Rockers. So Im all about budget racing, however looks like im gonna have to shead some cash for just even a set of cylinder heads and wonder what people think would be the best option.
The 318 in the car now is to just run around in till i get the motor built.
What I have waiting is a 340 Block .30 over with Speed Pro Hyperutetic Flat Tops, shot peened stock rods and a .20 over steel crank. All it really needs is to be hot tanked and checked, crank has been balanced.
So now for the heads.
I do right now have a set of J heads that are bare. They will most likely need damn near all machine work, guides, valves, springs, locks, retainers, and so forth. But i do have them.
So my options, get my J heads built, buy a set of the hughes iron heads, or grab a set of the edelbrocks. What do you guys think would be the best move?? Right now cheapest will prob be best, but im open to opinions. I know most likely the least im going to spend is $1000 so im aware.
I know the eddy's are just bolt on (beside the option of getting them checked first)
The Hughes to what Im reading are going to require a set of rockers ($325 i think)
