more seal whoas...
unknownsnake
Mason, MI
I cant figure how to put the roof seal in :/ I took them out over a year ago and it is puzzling me. First pic am I missing a peice or only certain trim packages have something that goes there? You can also see what looks like two tracks. Second pic is the new seal it has a big notch in it and a small notch. :book::read2:
Me no see a second pic.
If you need a pic I can get you one.
There should be a metal trim piece with some clips on it that cover the headliner gap. It fits in with the sail panel and the A pillar piece.
Shouldn't there be some little plastic pins that go in the holes on the weatherstrip and then into the holes in the metal?
I need a pic of this missing piece :/
there is one plastic clip on front and 4 where seal end near quarter glass
more seal whoas....sorry i thought it was about the east coast fishery.
If I remember correctly from putting roof rail seals in my Duster, there should be a stainless channel that goes in that upper channel. It should go from the front of the door following the channel all the way to the back of the rear side window.
Here is a pic of a cutaway seal in the top channel...
You can see more pics of an installed roof rail seal in this post
I just replaced the pass side seal on my car......What a PITA.
This pic may help. The stainless channel is screwed on thru the holes that are shown in your pic :cheers:
