Having trouble getting the valve covers to sit without hitting the intake. I don't know what the fix is. It is an Edelbrock Air Gap and Mopar valve covers> Any ideas on how to join them without leaks. I have no gaskets under them right now, so I don't know if I should double up the gaskets or grind something? You can look closely and see the space under the valve covers on the intake side? Anybody else use these valve covers? Also, I have 8MM wires and was wondering how I place wire looms on these valve covers? With the bolts being recessed and going down thru the top, are there wire looms that bolt up somewhere to keep the wires away from the yet to be installed headers?
