Are you entering it online or calling it in on the phone? Almost everyone I have ever given a code has said it is not working, but they were always trying to enter it too early in the online checkout. It goes in the boxes for a certificate number, or some such wording, very late in the online process after entering most of your info and I think during the actual payment method entry, right before a final review and submitting the order.Mine didn’t work either….
Mine also didn’t work.Mine didn’t work either….
Where did you guys get your code from?Mine also didn’t work.
Kinda pizzed me off….. ordered from JEGS.From 64mopar above. I'm going to try my code over the phone later today, I'll update with my results.
I got it from 64mopar. The ones I got from GTX John before the new year worked great.Where did you guys get your code from?
Just online where they’ve always worked. I’ll call Monday see what they say.Did you guys actually call Summit, or just try to plug it in online? With some codes, you have to actually call it in.
They'll make it work when you call. I've had a couple like that before.Just online where they’ve always worked. I’ll call Monday see what they say.
That's not necessarily true. For whatever reason, some of the codes just won't work with their online system and you have to call it in.If you you get those boxes and enter the numbers correctly but it does not work someone has already used that code or it has already passed the date.
They clearly want some folks to put some effort in to save some $. Can’t make it too simple or they are just giving away revenue.
I’m on your side! Picking up the phone to save a few bucks makes sense.It’s so simple my grandmother can do it. Pick up the damn phone and actually talk to someone. You guys are unbelievable
Check with @GTX JOHN by pm on this other thread.Are there any codes still available by chance?
