Motor Bracket Question
ron hug
Active Member
omaha
Copy and paste the link you are looking at. By the way, Welcome!
The Jegs/ Trans Dapt 4697 kit is for big block engines. I doubt it will work for a small block. It is also for 67 and up which is a bigger/different K Frame.
Trans Dapt to my knowledge does not make a kit for small blocks. I think they would sell if they did.
They could make one mount for 62-66 A Bodies, to install the 340, and 360 LA engines into early A's. Also they could make a set, to mount a small block into 67, and up slant six K frame, but thy don't. I don't know why.
Dave
