RichardJ916
I am installing a new 360 into my 1972 Duster this weekend , my question is do the bolts/nuts that mount to the 3 ears to the motor mater in the direction thet are installed. Meaning do the nuts go on the inside or the outside, I do know the the ears on the brackets go towards the inside but unsure of the direction of the bolts/Nuts....
Any pictures of mounts and rubber would be helpful as well thanks.
Also i am using the same rubber mounts that came off of the 273 motor that i am removing, i think all the mouts are the same, meaning the rubber part of the motor mount is the same no matter what motor i am installing, if this is correctly thinking.
The 360 motor can with a motor mount and bracket that fit into a B body, I removed the rubber part of the mount from the 273 and putting it on the 360 bracket... Does this sound correct.
Please let me know what if any trouble this will cause....
:burnout:
:burnout:
