Thanks for baring with me. I have V8 K frame. I reused my 340 brackets with Schumacher Poly Loc biscuits on my R3 360 having to shim the drivers side bracket. I tried to drop in my R3 360 but will not sit completely onto the K frame. If I need a 318 bracket does anyone have one to sell. Any pictures of a 318 & 340 bracket side by side?
Ok, where getting close. I have done extensive research on this,to install my 360.It sounds like your 360 mounts the same as a standard 360 so.........
Right side (passenger): 318/340 mount should work,I believe they are the same.This is a picture with a 318 bracket,right side.If your 340 bracket doesnt fit,I believe I have a 318 bracket for that side.This is the easy side.
Left side (Drivers): This is the side that needs the 340 mount. A 318 mount will not fit this side,as you see in the pic. I have given you a pic of a 340 mount and a 318 mount from this side. You need the 340 mount for this side period.
On a side note: There are 2 different sets of 340 mounts. There is a A-body and a E-body 340 mount. The holes where the biscuits mount on a A-body car are more forward,the holes for a E-body car are further to the back of the mount. Make sure you have a A-body mounts.This is imperative or your engine wont sit right.I have seen people on ebay selling 340 mounts,saying they will fit Darts,Dusters,Challengers,Cudas. Not true,they must be A-body.
Any pics of what you have would also help.
