moparmat2000
I have a 74 dart spool type k frame and 318 out of a parts car for my cuda build, and i may be going with a stroker 360, instead of building the teen up. Will the motor mounts currently on the 318 bolt directly to the 360 block in the same location and work. I found a bare mid 70s 360 block with main caps, for $100. I know i can use some things off the 318 on this engine, will the oil pan off the teen fit the 360, or do i need to get a 360 specific one as well.
Thanks
Matt
Thanks
Matt
