treetrimmer12
Finished with pass side motor mount and fuel pump installation then went to drivers side. Motor mount rubber separated but bracket appears to be bent and not settled nowhere near where it should be. Unable to locate a pic of what the bracket should look like, attached is my drivers side motor mount. Never get a socket onto nut mounting top of motor mount.Does this look ok to you?
Do you have to remove the bracket and motor mount, install new motor mount onto bracket then bolt back onto the motor then lower the motor with the bracket onto frame?
