TNT440_Cbody
Forget expensive crappy plastic aftermarket clips that you have to file down with a Dremel tool to make work... That's what I *was* doing until I thought, "F*** this!!! There has to be a better way!"
I bought a pack of 100 of these from McMaster-Carr for $6.95
www.mcmaster.com part number: 91010A110
If you decide to go this route, be sure to measure the diameter of your trim holes and count them all before ordering!!! I actually needed more than 100 to fill ALL the holes but decided that skipping a few wouldn't hurt anything.
The holes in the top vs. bottom strips of trim on my car were slightly different, with the top ones being larger. However I took the gamble and although the top trim is a little looser than the bottom trim, I don't think that it is going to fall off. If it does, I'll let you know. :toothy10:
She's a-comin' along!!! :cheers:
