kingvern
Ok i have herd a lot of people talking about moving there rear end back 1in to allow for a bigger tire. How is this done are there any tech articles on this.
I moved mine back 1/2". I used some 1/2" thick aluminum plate to make the spacers. Now my wheels look centered in the wheel wells.
I thought some people drilled extra holes in the perches and shock plates and just moved the rear end back on the springs? I like the spacer idea.
OK, I understand about the spacer behind the front spring hangar to move the rearend back in the wheelwell. But I'm curious what effect, if any, this has by also changing the angle of the spring shackles at the rear of the leaf springs.
Comments???
