gerty
After hearing nothing but good reviews on the Mopar Chrome Ignition box on here, I think I'll try one. Wiring is not one of my strong points so I have a question.
I have a '75 duster with a Magnum 408 stroker (not up and running yet but close) with the stock ign.box with the 5 pin connector setup and a dual ballast resistor. I have a Msd Blaster 2 coil already because I was about to use an Msd box but changed my mind. I'm thinking the 4 pin chrome box should work ok. Will the Blaster 2 work with the dual resistor and chrome box or will I have to somehow wire the 1 ohm Msd resistor into the car's wiring?
Bob
Bob
