[SOLD] MP hydraulic flat tappet Purple Shaft .508 cam/lifter kit - used
physixx
Edison, NJ
I have for sale a nice used hydraulic flat tappet small block MP purple shaft cam and lifter kit. It was taken out of a mild 318 bracket engine t hat sat for a few years. The lobes look great with just the usual lifter wear. The lifters were removed and put into a lifter box that is labeled so they go back in an engine in the same lobe that they came from. This is the MP .508 lift cam and lifter kit P/N P4120233AE.
http://www.jegs.com/i/Mopar-Performance/312/P4120233AE/10002/-1
The specs are as follows:
Advertised Duration: 292°/292°
Centerline: 108°
Lift: .508"/.508"
RPM Range: 2800 to 6200
I would like to get $100 plus shipping for the kit.
Ken
Edison, NJ
