You're correct Stixx, but my problem is the cases where the dyno 2 dyno numbers are more than 1-2% off . IE Dyno 1 says 480 hp and same engine on Dyno 2 says 520 hp that's almost 8.5% difference. I am not saying that's the case here but if you watch this stuff like a hawk like I do you can find many examples. Always watch the tq/ci figure. There are 3 dyno shops in my area and the one that makes the customer the warmest and fuzziest is the busiest. Hint--It ain't mine. J.Rob
I can get that done on the SAME dyno, the same day. Real simple. Get to the weather station, isolate it with a vaporizer. Like magic it make 7-10% more corrected power.
It takes a lot less than 530hp to push a 3200# A body to 114mph. 530 at 3200 should be north of 120 and closer to 125.
Go watch reruns of Pass Time if you want to see inflated hp numbers and crappy MPH.
