jet_wrnch
Active Member
I'm workin on my 71 valiant that I just redid most of the wiring on. I put in an MSD6al box and mounted the battery in the trunk. I also went with a ford style starter relay(a 4 post)to clean up wiring under the hood. My problem is really only two wires. I need to know which wire to use for the ignition wire on the msd and which wire to use for the starter solinoid. wait, one more since I mounted the battey in the trunk and have a seperate fuse box for fuel pump,fan, waterpump etc. where does the factory fuse box get its power from? Do i need to run another lead from the battery to the factory box? I hate wiring
