MSD compatible distributor
Mopar92
Lewisburg tn
What is a nice daily driver new distributor that will work with my MSD 6AL ? This is going in my mild 360 LA build. Thanks for any suggestions.
A stock Mopar electronic ignition distributor will work just fine.
I run 10's with a Pep boys OEM electronic dizzy. MSD's allow easier tunablity, but you can always find out what your curve is and translate it into the MSD later if your wallet is a bit lean on funds.
Just about all modern new distributors will work ,the 440 source ones are junk
Do you have a distributor now or are you looking for one.
I am now. After contemplating chinese distributors, parts store, rebuilt stock... I just pulled the trigger on the Msd. I’ve had good luck with them in my dirt cars.
I would think a distributor from Mancini ($122) would be about as cheap and dependable as you will find anywhere new!
