dgc333
I picked up an MSD 6A and went to install it today and it wouldn't start. Followed MSD'd trouble shooting guide and the MSD is producing a spark when either the white wire is grounded or the purple & green wires are jumped.
This tells me that the green / purple wiring is not getting a signal from the magnetic pick-up in the distributor. Double and Triple checked my wiring and connections with no luck. I can re-hook up the ECU and the engine runs fine.
What I did do was leave the MSD hooked up like it was a points ignition and used the (-) coil wire from the ECU to trigger the white wire on the MSD. Runs great.
My questions is shouldn't I be able to eliminate the ECU and trigger the MSD right directly from the distributor?
Any insites are welcom.
