My 340 bare block
Small Block Mopar Engine
  1. Keven S. Clickner
    Keven S. Clickner FABO Gold Member FABO Gold Member
    109
    17
    Aug 27, 2020
    West Central Indiana
    Local Time:
    8:06 AM
    Some pictures of the 340 block that I received with my 69 Dart and parts package. What I'm going to show you here are some holes drilled in the lifter valley .
    I thought that a friend of mine knew something about the past of this block , wrong. I was hoping he would be able to tell me where the machine work has been done and what these holes were drilled for.
    A description first.
    At the front of the block right hand side passenger side oil galley there's a hole drilled directly below the large hole going into the cam cover at the front wall. I don't exactly what that hole is for in the wall certainly not a drain into the timing chain area. It's about 9/16 in diameter maybe 5/8. The drilled hole is about an eighth of an inch diameter. And the same location on the left side driver side there is a center drill mark. As if they maybe were planning to drill a hole there in the left-hand oil galley.
    Then looking to the rear of the block there is another hole approximately 1/8 of an inch. That hole is located in the passageway leading to the pressure send port.
    I'll post a cpl. pics maybe some of you guys 'n gals might know what was up here and the thinking and reasoning behind it. I've read the Guitar Jones Oil mod thread I don't believe any thing like this was in there. I can always plug them. not a problem , and go with something I know a little more about like some of the guitar Jones mods.
  2. Keven S. Clickner
    109
    17
    Aug 27, 2020
    Local Time:
    8:06 AM
    Oops here are the photos
    • Agree Agree x 1
    • HemiSSDart
      HemiSSDart Dartus Interuptus
      1,494
      1032
      Feb 20, 2013
      Illinoisy
      Local Time:
      9:06 AM
      Is that the original block to your car? The reason I am asking is that I have been searching for my original block from west central Indiana for the 69 GTS I bought in 1995. If it is not your original, do you mind posting the VIN? As far as the mods, I have had dozens of 340 blocks and have never seen anything like it?!?
      • Agree Agree x 1
      • MoparMike1974
        MoparMike1974 FABO Gold Member FABO Gold Member
        2,745
        1980
        Jun 16, 2017
        Maryland
        Local Time:
        9:06 AM
        They appear to be drilled directly into the oil passage. Not sure what the purpose would be. I see two holes in the first pic and one in the second.
        I would drill, tap and install plugs in them.
        • Agree Agree x 4
        • ocdart
          ocdart Inland Mopars Car Club FABO Gold Member
          9,449
          2682
          Nov 5, 2006
          North OC, SoCal
          Local Time:
          6:06 AM
          I haven't seen holes like that before.
          One of the tricks back in the day was to drill holes in the lifter valley to aid oil drain back to the crankcase.
        • Keven S. Clickner
          109
          17
          Aug 27, 2020
          Local Time:
          8:06 AM
          The block is not original to my car , a '69 273ci . Believe it is '73 . But I will post vin within the next day . Sourced the block locally though . Sheldon il. 60966 .
        • Keven S. Clickner
          109
          17
          Aug 27, 2020
          Local Time:
          8:06 AM
          There is a center drill mark/touch on the far side in 1st pic not drilled thru .
        • Keven S. Clickner
          109
          17
          Aug 27, 2020
          Local Time:
          8:06 AM
          Not these . These are in high pressure locations .
        • Plymouth 65
          Plymouth 65 Floorable Deplorable
          1,257
          1177
          Jun 27, 2016
          Mich
          Local Time:
          9:06 AM
          I'd plug those holes if there through to the oil passage. If not, I'm pretty sure it will lower your oil pressure. 65'
        • famous bob
          famous bob mopar misfit
          17,854
          7297
          Aug 14, 2011
          okla
          Local Time:
          8:06 AM
          Think I`d tap the two across from each other and tie them together , would have an equalizing effect on both sides of the block. the others I would plug-----------------------jmo
          • Like Like x 1
          • yellow rose
            yellow rose Overnight Sensation FABO Gold Member
            25,577
            21672
            Jun 19, 2015
            Under The Gun
            Local Time:
            6:06 AM
            That block has a tube in the passenger side oil gallery. That means unless they drilled holes in the tube there is no oil to the lifters. If they plugged the feed to the drivers side gallery like they should have, there is no oil to the lifters on that side.
            My best WAG is they drilled those holes to get some extra oil in the lifter valley in the hopes of getting more oil to the lifters.
            I’d drill and tap them and plug them. You don’t need all that oil blowing around in the lifter valley. There is already plenty of oil there.
            Just my best WAG.
          • Keven S. Clickner
            109
            17
            Aug 27, 2020
            Local Time:
            8:06 AM
            Oh yeah
          • Keven S. Clickner
            109
            17
            Aug 27, 2020
            Local Time:
            8:06 AM
            Of the two locations at the front of the block only one is drilled through the other is just marked. At the back of the block sending unit passageway that is drilled also. Yes big bleed off from both of those locations. no tubes have been installed in oil galleries and there are no feeds blocked. I believe they were just at the beginning stages here and left incomplete.
            Yeah it looks like taps set screws red Loctite. And I'll pick and choose from the Guitar Jones oil mods for what may apply to me
            Just checking in to see if anybody recognized what might be going on there . since I have no history on it, it will be a little rework and restart.
          • yellow rose
            25,577
            21672
            Jun 19, 2015
            Under The Gun
            Local Time:
            6:06 AM
            In the top picture of post 2 is that not a crusty copper tube I see breaking thought the lifter bores? Or is it just some crusty crap in the gallery?
            If there is no tube in there I have no idea what they were doing.
            If you are going to do any oil mods, spend you time and money on the inlet side of the pump. Unless you are turning 8K plus, that stuff after the pump is just busy work.
            Work on the inlet side of the pump. That’s were the restriction is, and it’s the best bang for your buck.
          • toolmanmike
            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
            54,279
            40059
            Jan 18, 2006
            Iowa
            Local Time:
            8:06 AM
          • yellow rose
            25,577
            21672
            Jun 19, 2015
            Under The Gun
            Local Time:
            6:06 AM
            I see the oil there, but looking at it really close that may just be some crap down in the lifter bore where the oil gallery intersects with it.
          • toolmanmike
            54,279
            40059
            Jan 18, 2006
            Iowa
            Local Time:
            8:06 AM
          • Keven S. Clickner
            109
            17
            Aug 27, 2020
            Local Time:
            8:06 AM
            yellow rose :
            Thank you for the insight above .
            As far as what you're seeing in the photo there I am not sure . there is a pool of oil around the lifter bores and between. I painted some 140 weight for protection. Apparently they used a die grinder with a ball carbide and outlined below the lifter bore opening and between the lifter bores. And I no longer have any idea who "they" are or were. Laughing out loud.
          • Keven S. Clickner
            109
            17
            Aug 27, 2020
            Local Time:
            8:06 AM
            • Thanks! Thanks! x 1
            • Keven S. Clickner
              109
              17
              Aug 27, 2020
              Local Time:
              8:06 AM
              Right there
            • Keven S. Clickner
              109
              17
              Aug 27, 2020
              Local Time:
              8:06 AM
              There was a clay wasp nest in about every through hole in the block
            • Keven S. Clickner
              109
              17
              Aug 27, 2020
              Local Time:
              8:06 AM
              Yeah that oil is pooled in channels ground apparently with a spherical carbide. They're around all the lifter bores blow the opening and in between the pairs. I don't really see the use for it. But as it is I don't think there's any harm.
            • Keven S. Clickner
              109
              17
              Aug 27, 2020
              Local Time:
              8:06 AM
              This is something certainly in consideration for some time now for me. Is there anything you could recommend for light gauge tubing for the oil pump pickup? I don't have the ability to bend steel tubing here not even light wall stuff. I've looked for 5/8" seamless tubing mandrel bends but I haven't found any . I'd be surprised at this point if they're out there.
              Was going to do a mock-up in something like flexible Appliance gas line. or soft copper tubing. I don't think the soft copper tubing would be strong enough as the finalized pick up tube even with some support to withstand what might be going on in an engine crankcase or chassis, vibration, impact and such.
            • Keven S. Clickner
              109
              17
              Aug 27, 2020
              Local Time:
              8:06 AM
              And now for the restoration buff's the collectors and the sentimental, much appreciation respect from me to you.
              The VIN on the Block to follow here directly.
            • Keven S. Clickner
              109
              17
              Aug 27, 2020
              Local Time:
              8:06 AM
              And for the aficionados of the best of the Worst in 70s shag carpeting . . .. I hope I haven't ruined the value here because I did pick out the remains of the orange shag that was embedded in the pan rail.
              My comedic attempt aside if somebody has the balance of the matching Vin car parts for this engine block. I would certainly part with it for the time being. But after I sink some money into it maybe not so easily. there are no main bearing caps but I have two sets of 318 caps I was going to take to the Machine Shop to least get started with. At least so torque could be applied to the block for the checking of dimensional trueness or lack thereof. (Questions on that will likely end up in a different thread very soon as I will need some healing of my ignorance.)
