My 64 valiant
64val67gtx
64 sl6val 2dr 67 gtx 4spd
Eugene oregon
First off i need to say this is my first post on here, the early a-body disucssions is very cool, im only 30 this is my 3rd valiant.
[ame="http://youtu.be/D9jXX1GkkJA"]302 Found[/ame]
[ame="http://youtu.be/lTL4nwVhdww"]302 Found[/ame]
[ame="http://youtu.be/kFmBpl2fKFg"]302 Found[/ame]
Got this car for cheap, from the org owner.
Turns out it shoulda had a 170 in it, but the old ladys daughter ran it out of oil.
Also she hit a deer in it back in 79, now it has a signet or a 200 hood on it.
Things i have done..
Oil&filter
Champion plugs
used points
accel coil i had laying around.
New sending unit
new bulbs everywhere
new fuel pump
new belt
new battery cables
rebuilt carb
new ballasist resistor
new voltage reg
new starter cyl
new dimmer switch
new fuses new fuel lines/ hoses
good used batt
new 9'' drums
new cap
new rotor
fuel tank was dipped a pressure checked
new shoes
all 4 new wheel cly
new brake hardwere kits
new brake hoses
New tires
rebuilt by me master cly
new frame connectors and tourge boxes
used heater fan
new fuel filter
used raid outta a 66 val with ac
used grille off parts car
used headlight rings off parts car
im sure im leaving some things out, i have done all the work on this car myself.
[ame="http://youtu.be/scGNUmWAzzg"]302 Found[/ame]
This was from 2 days ago.
Congratulations on a great find you have, and welcome to this great site :cheers:.
Looks like you have been down this road many times :thumrigh:
Very nice collection you have going.:glasses7:
Should have posted the video you took hanging out of my truck window at 60mph filming it
Let me welcome you while I am here Jeff :thumrigh:
So you must have been driving and helped 64val67gtx get this nice 64 Sedan home :cheers: Jump on in and enjoy :glasses7:
Nice looking project. Have a 64 Valiant Signet Vert. Fun to drive, and always get looks.
Looks like you're in for some fun floor board work in that one! :)
Ya shoulb pretty easy i already have the floors seperated from the frame rails. so i just need to cut out the floors on this car and install should take a month or so.
Very nice! I have almost the exact same car. I've had mine for 15 years now and I'm just starting on a true restoration. Your video gave me a lot of memories of bringing mine home in fairly similar condition. I'm about to do some floor replacement myself. I look forward to following your progress.
Nice project car. Mine is a 64 DartGT 340 4 speed but Ive also owned 2 other /6 cars also and one was in a junk yard for 10 years hood open for at least 7 and ran great with tune up and oil change for a couple of years then parted it out for parts on my current 64 . By the way it kinda sounds like you need to adjust the lifters a little : )
Wait a second, that has a fan shroud. Did that come with the car? I didn't think the '64s came with fan shrouds, especially on the Slants.
ETA: Ah, I see that wasn't there before. Did you make it? Looks good.
Ya it came out of a 66 valiant with ac, the org raidiator got scrapped by some moron so this one works for now..
You have done a Lotta work on the floor, wow, best wishes with the project.
The floor looked almost as bad as a RockSalt -belt Northeast car,
but, the fenders and hood are still there.
The Valiant I had came from California, it was a joy to work on a
not rusty car.
