My 68 barracuda
racerdan80
OKC, OK
I've had this car since autumn of 2009, once finances got squared away and an honest body shop the work could begin
1968 318 904 currently 7.25 with 2.76, soon to have 8.75 with 489 case with 3.23, TT1 Avacado green exterior, medium green metallic interior, rallye dash
I did the repairs on the inner fenders. Quarters, rockers, front floor pans replaced, frame rails by suspension arms repaired by Jerry at www.cjautobody.com
quarters finished, soon to be blocked sanded, then final coat of primer
I've been on this site for awhile, finally got some photos worth posting. Thanks for all the help on the tech forums, and yes I'm keeping the 318
You should maybe start a thread in the Members restorations forums.You can post all your pics there and add as you progress.Nice work you,ve been doing so far.:thumbup:
fender repair, driver's side at the front was crushed in and had several creases. Drilled off headlight mount, torch, brass hammer, several body dollys was able to re contour. Patch panels were required as well for both sides
