My 68 Valiant
72, You did do a story on the lower bearing on this site right ? Was it a sticky ?
3-17-17
Got the driver side header on, what a pain in the ***! Had to juggle the starter steering box and header at the same time. I also had to pull out a brace that went between the trans and the motor,that will need to be addressed at another time. And yes I did mess up one of my remflexes.(sometimes I hate myself.)
My motor mout pad was broken so those are on order from Rockauto. Ill keep you posted
Happy Saint Patricks day Im headed for a Guiness
3-18-17 Got the steering column back in with the new coupler. All seems to be fitting well. Ill pin them when I make sure all issues are taken care of.
3-19-17
Painted up LCAs with rustoleum red primer and gloss black.
Made a tool to press in Bushing and pivot into LCA The size pipe I used is 1-1/4 RIDGID CONDUIT(not emt) it fits the lip of the bushing perfectly. 1-1/4 galvanized plumbing pipe is the same size. I gotta begrudgingly give a thumbs up to the Harbor Freight press. HF is good about 20% of the time.
It has already paid for itself.
3-25 17
Installed Passenger side header. A bit easier than the driver side. Used Doug's gaskets.
Installed new motor mount pads on both sides.
Noticed that shifter cable was run incorrectly and will interfere with exhaust. I will have to reroute properly.
By the way, the info on this sight has been invaluable.
A little progress today Got the urethane boots on the torsion bars. Worked them on from the LCA side, boil then lube up with WD40
and push on.
10-8-17 Took most of the summer off helping a sick friend and squaring away some family stuff
Front brakes and rear brakes are done. I need wheels and tires.
Going to Pomona swap next weekend to see what I can find
11-5-2012
Brakes are properly bled. Wheels and tires are on. alignment is in the ballpark enough to get it to the shop.
I need to get an exhaust system(Summit) and heatproof some lines and cables. Need to install the hood and then go through a front to back nut and bolt.
Got the summit dual exhaust hooked up to my Dougs over the weekend. A few adjustments were necessary, but overall not a bad install.
Fired it up to move it around. TQ had fuel pouring out between the air horn and main body. I yanked that off and put o n an Edelbrock 600 performer that I rebuilt last year. Right now sitting on a spread to square adapter. Runs really well after it warms up. Next I have to adapt the cables to the Edelbrock Then dial in the idle etc etc.
I wouldn't cut up a nice hood. I bought a VFN fiberglass hood for mine and put a 6 pak scoup in it.
Alright Since I cant seem to keep an actual log, Im going to list my improvements, not necessarily in order, but definitely with the help of FABO Members.
Front suspension and brakes(Right Stuff Detailing Kit)
New Lower ball joints ,tie rods and rod ends, LCA bushings,strut rod bushings, barracuda torsion bars.(892,893)
new front wheels and tires 15X6 P205/60/15 LBP. new front shocks, new front brake lines MC and prop valve
new brake lines front to rear, rebuilt 9" rear drum brakes on my 7-1/4(new diff gasket)
New rear tires 225/70/15 on 15X6 Wheels SBP
Some wiring repair (not finished) new starter relay, Ammeter is bypassed. New mini starter, new battery
New AVS2 650 Carb and adapter, Air cleaner fuel pressure regulator and gauge, new fuel filters and repair to fuel lines from tank.
New Dougs Headers and header back exhaust(summit)
New Z gate shifter, new trans cool lines with AN fittings
Gas struts to raise deck lid
Stock hood reinstalled.
Got my front end aligned today so I am ON THE ROAD!!
To Be done soon:
New Radiator on the way.
Rear Shocks
Points Distributor with Pertronix Module and Flamethrower coil
Rear spring bushings(or new springs)
