my 69 big block dart-512 stroker
pushrod
70dart 340
greer,s.c.
A few pics of one of my never ending projects.
Nice car. Is that a factory color? Do you know the color code?
I believe it is the orig. factory color. It was painted when I bought it But I will get the code as I need to repair al ittle rust coming back. Yea it is fast. Makes 650 at the crank with 323 gears and 2800 stall. Just a fun steet car.
I like the color and especially what's under the hood, looks like a ground pounder and I see you bit the bullet and installed an aluminum pump, good choice. A little advice tho, you shouldn't tie your plug wires together ya actually want to keep them seperated a little using those wire loams or some other, you could end up with tracking problems as the plug wires age.
Terry
whoses kit did you use to build the motor I am getting ready to order my bottom end and was just woundering
Thanks for the good words. I used the 440 source kit and their Stealth heads with a mild port and polish.
