Csommers
Started working on the car again. Rad support is welded in and i ran some 3'4 square tube for the bracing/fender mounts. Hung the fenders just to make sure everything lined up and it looks pretty good. Mounted the pedals. The steering column shouldn't have to come out again. Ordered a rear inner valance and rear deck cowl. There's a piece of flat tin that runs across the back where the bumper brackets mount. This will probably be the next piece replaced. I just plan on using a piece of flat steel.
