Dartfreak75
Restore it, Dont part it!
Wow bud that looks great nice work keep at it!
Thanks Kevin I’m happy with how the first one turned out. Long way to go but wanted to look at something that actually could be completed.Wow bud that looks great nice work keep at it!
but that's $24.99 plus the cost of the mineral spirits plus the week or so. my way does the same job for free and now, so no waitingSoak the pistons in mineral spirits for a week or so, blow the loose crap off with brake clean.
Then use one of these tools to clean the ring grooves.
Lisle 24000 Lisle Ring Groove Cleaners | Summit Racing
You forgot the $5.00 for bandaids when the ring cuts the crap out of your fingers.but that's $24.99 plus the cost of the mineral spirits plus the week or so. my way does the same job for free and now, so no waiting
did i mention for 'free'?
neil.
i got that covered, i mentioned taping over the end as it's sharpYou forgot the $5.00 for bandaids when the ring cuts the crap out of your fingers.
Yes I used the old ring trick many times, and cut myself each time.
So true, I would still soak them in mineral spirits to soften the carbon up.i got that covered, i mentioned taping over the end as it's sharp
so i guess a roll of tape then, lol.
oh, i totally agree the tool is slick but the old rings are always to hand (don't have to remember where the tool is) and did i mention 'free'?So true, I would still soak them in mineral spirits to soften the carbon up.
The ring groove cleaner tool works pretty slick, I have used one for years.
I have the same one the little expander broke the first time I used it and had to but a new one after that it worked great just a heads up if you need it again lol. I didn't see where you posted what cam are you using? Is it a roller cam or flat? You have the specs on it?View attachment 1715759989 View attachment 1715759988 Cam tool I used.
I always have to save them to my phone and flip them ans resave them lolTrying to add pics but they keep showing up turned sideways. Not sure why
It’s just a stock 5.2 cam. It’s a Magnum so factory roller. My original one had a couple wear spots I didn’t like on a few lobes. I found a guy on Fakebook who built a 390 stroker so I bought his oem cam.I have the same one the little expander broke the first time I used it and had to but a new one after that it worked great just a heads up if you need it again lol. I didn't see where you posted what cam are you using? Is it a roller cam or flat? You have the specs on it?
Thats great! Make sure you check your roller lifters too did you get a set of them with the cam?It’s just a stock 5.2 cam. It’s a Magnum so factory roller. My original one had a couple wear spots I didn’t like on a few lobes. I found a guy on Fakebook who built a 390 stroker so I bought his oem cam.
