Kendog 170
Let the boy go !
Good stuff
As of right now, no offset lifters. just going to live with what i get as far as pushrod angle. I will be running 1.6 rockers though.Will you use offset intake lifters to help correct pushrod side angle? Also 1.6 rockers move the pushrod closer to the rocker shaft and help with the inverted angle. We did both and helped straightened the push rod angle LA SBM's suffer with. With the 1.5's we needed to make valve cover flanges with reliefs for reverse flange covers and weld them on. The 1.6's gave much more room.
The W-2 covers had the notches already cut in but the height did not clear the rockers we used. with the 1.6 rockers we won't have to glue and notch the gaskets for the taller covers
Nice work I like the way you are moving the hole with a pressed slug and I like the intake work. Should be a monster when its done. Engines are compressors, The more you get in there the more you can compress then Big tubes to get it out . FLOW,
Mopar Performance reverse flange. $400 way back I sold them to a member on this sight. They were machined off flat.OldMan, where did you get those valve covers ? sorry, Not trying to highjack this awesome thread.
Somebody needs to make a set of valve covers like that, I'd buy em yesterday!Will you use offset intake lifters to help correct pushrod side angle? Also 1.6 rockers move the pushrod closer to the rocker shaft and help with the inverted angle. We did both and helped straightened the push rod angle LA SBM's suffer with. With the 1.5's we needed to make valve cover flanges with reliefs for reverse flange covers and weld them on. The 1.6's gave much more room.
Nice, very nice.After finding out my old iron heads couldn't be saved I figured it was time to dig out the SM castings I bought a few years ago. And of course I can never just take the easy route. ( whats the fun in that. Lol)
So after studying all of Pbr's porting threads and then some, I decided it was time to get grinding.
Here's where I'm at thus far, please give any and all tips, pointers, advice you can.
For now they will be going on a sbe 5.9 mag with a 242/[email protected] .600/.600 110 cam. Have another engine on the stand to be built and will either be going compression and cubes or a supercharger. Haven't decided on that yet.@turboking15 what will the application be? Will this be a 330cfm turbocharged deal?
Lol. My turbo engine already has a set of mildly ported edelbrocks on it.I was hopeful with your screen name that this would get a turbo.
I just LOVE it!Will you use offset intake lifters to help correct pushrod side angle? Also 1.6 rockers move the pushrod closer to the rocker shaft and help with the inverted angle. We did both and helped straightened the push rod angle LA SBM's suffer with. With the 1.5's we needed to make valve cover flanges with reliefs for reverse flange covers and weld them on. The 1.6's gave much more room.
I did not, that way if I had to do any welding in the port I wouldn't have to fight with cleaning it out 1st. Once I have the new push rod holes drilled I'm going to weld both ends of the plugs shut so there will be no chance of a leak. But from what I've seen thus far I'd be willing to bet the press fit would be enough to not let it leak.Do you put any type of sealant on the bar stock that you press into the pushrod holes?
Hopefully neither vacuum OR oil.I did not, that way if I had to do any welding in the port I wouldn't have to fight with cleaning it out 1st. Once I have the new push rod holes drilled I'm going to weld both ends of the plugs shut so there will be no chance of a leak. But from what I've seen thus far I'd be willing to bet the press fit would be enough to not let it leak.
I noticed you also tubed the head bolt holes, did you break through the casting to the tube anywhere when removing that protrusion into the port? I couldn't get an accurate guage on how thick this area was on mine so I just smoothed it out a little with a cartridge roll.
I tubed them both and port to it just for safe measure.You only have to tube the head bolt hole that has the oil hole to feed the rockers.
The other one you just take it out until it breaks through and leave it.
