My DIY Smoke Machine
dibbons
La Paz, B.C.S., Mexico
Empty glass jar of honey with metal lid. Inserted two tire valves (one retains the inner valve) and one soldering iron. Inside is a cotton sock soaked in mineral oil. A bicycle pump is connected to the tire valve with the inner valve still retained. The other tire valve is open to the air and is where a rubber hose will be attached to send the smoke to the area where we are looking for vacuum leaks, etc.
All I need is a 12 volt battery and I can make smoke easily. Haha
For those interested, here is an outside photo of mine:
Looking at the top of the 2-1/2 gallon spackle bucket, you can see:
  • Oxygen tubing for air in
  • Larger clear plastic tubing for smoke out (with funnel for stuffing in larger holes, such as gasoline filler)
  • 12VDC in for heat
Inside, I used some nichrome wire I had a spool of, the spool gave its resistance per inch, I calculated a value to give me about a 20A draw, which is conservative for my 10ga feed wires, cut the proper length of nichrome wire, then wrapped it around a piece of tubing to make a coil, and connected the ends to the brass screws in the lid.
I used some fiberglass mat to line the bottom of the bucket, and stuffed some of it through the center of the coil of nichrome wire.
I laid the wire in the bottom of the bucket, then saturated the fiberglass with a couple of cups of baby oil (might as well keep my fuel system smelling baby-fresh!), and snapped on the lid.
The two lengths of tubing are connected to brass barbs attached through the cover with nuts.
I attach the input oxygen tubing to an old nebulizer (asthma) compressor that probably everyone (or a relative) has lying around somewhere, attach the clamps to a 12V battery, and, within a minute or two, there is smoke pouring out of the reversed funnel under just a little bit of pressure.
It's not a $2,000 Snap-On smoke generator, but I have managed to find leaks with it.
– Eric
