I’m hoping to get the front wheel bearings replaced tmrw and go to a cruise-in tmrw night. Also, I should have some pics of a pretty big update here in a few weeks!
Yup! Better get my *** in gear huh?11 days and a wake up....better get busy. See you at the Nats....as usual.
Is that all?Biggest items on the list to get done for the Nats are....
1. Swap out 3.23 gears for 2.76
2. Correct pinion angle
3. Change wheel bearings
4. Fix noise in rear brakes
5. Replace u joints and install longer driveshaft
6. Install QA1 UCAs
7. Get alignment
8. Maybe patch rear passenger floor pan and install subframe connectors.
9. Install insulation and vinyl floor from valiant parts car
10. Build door panels
11. Reinstall interior
12. Maybe dye front seat
13. Maybe tint windows
Lol! Realistically I can do without all of those things except the wheel bearings, rear brake noise and I really need to change the pinion angleIs that all?
I’ll probably do it at the transmission since I got the tailshaft pointed down too much when I build my transmission crossmember.Pinion shims are cheap, figure out the degree you need and order them asap, so you will have them.
Fixed it.Hey, Caleb. Your inbox is full.
That 72 valiant 4dr that I bought last year had one in it.75slant6, where did you get the vinyl floor mat from is it new or used? I had a 74 Duster that had one and would love to get one for my Dart....Love your car by the way.
Well fine then!! LolPictures or it didn't happen
I'm pretty sure he sold this car and bought a Honda and installed a Huge muffler and living in his moms basement
