JungleCrow
So this 383 B engine fell into my lap and it doesnt seem to run right. When it is running the engine rpms fluctuate. It runs like some sort of race cam where it idles high then low then high then low making a varooom... varooom... varooom... It runs so rough too. Shakes the car inconsistently. But sometimes it idles ok but like its about to die like the spark isnt there. Sometimes it picks up sometimes it dies. Its just not constant at all so Im not sure if it is a cam thing. When I loosen the distributor to mess with timing... Just loosening it make it run better. Retarding the timing made it run smoother but then it would die when I gave it gas and once it shot fire out the carb. I have a new distributor coming in to replace the ignition box style. I replaced the coil cuz it was leaking oil but that didnt fix it. Im just not sure what it is. Anyone got any idea?
