Hey FABO, I need some advice. I put a 400HP 340 in my 68 Dart 270. I tried a burnout and got some wheel hop. After the burnout attempt it was hard to push in the clutch. I got home and found that the z-bar was hitting the header and the rubber engine mounts had small tears in both sides. I never knew there was a concern about engine movement. What is the solution? Solid mounts? Torque strap? The Dart is just a weekend driver. Thanks FABO.
