BenNSB
Finally welded the perches on the rear and installed the gas tank. Unfortunately the girdled aluminum cover won’t work. Mocked up the shocks and going to see if I can run the Mountaineer rear sway bar. Hooked up the brake lines and bled them. Also got replacement door panel trim for the front doors.
