ok.....
ok.....
ok.....
yes, on that head. I'll need another look as time permits. Had something going on this evening, but I would guess it's the setting of the seat.Nice...
Was that one valve on that one head the only one that seemed a little high?
Did you do anything about it or just adjust the rocker accordingly when the time comes?..
Agree. I would imagine the valves are all pretty close to the same length. The valves are just steel and not stainless I assume?yes, on that head. I'll need another look as time permits. Had something going on this evening, but I would guess it's the setting of the seat.
yes, and I can see people buying the bare heads for about 420.00 and loading them up with nice hardware. Problem is if you have to pay a machinist to perform some of the work, then the money gets lop-sided in favor for "loaded heads" to a DIY guy like myself.Agree. I would imagine the valves are all pretty close to the same length. The valves are just steel and not stainless I assume?
exhaust side is good. Mildly ported 308 heads are just as good. But in my opinion, the 308 head might be the best small block head from the factory on the exhaust side. So I just gave SM a compliment.Awesome job as usual! What's your opinion of the exhaust side?
Nice they don't need a back cut. There seems a lot of good going on here for the price.Stainless
I don't have a way to accurately test the springs. Retainers/locks are suppose to be chromoly.Any intentions of testing the spring pressures, hardness of the retainers or locks or?
Can't beat first-hand testimony. thanksSeems like the springs were 145# seat and 350+ at .500 and plenty of room to go .650 lift. I do.
I've put several 6500 rpm hits on them and everything is still in one piece.
Nice job on the video. I can’t wait till Wednesday maybe I will get off my lazy butt.
