Since this this the ported version.....is the seat area any better? any combustion chamber work?
I couldn't help it, by now I would have been going at them with a cartridge roll!All the valves had slightly different shimming under each spring, between .053 and .073.
Seals were all tight to the guides (getting replaced anyways)
Some casting flash left in 3 out of four exhaust ports on the same side (Best/worst ports pictures)
Intakes were even better, only one small spot where the head bolt goes, and only on one port.
Core shift, based on the porting work, seems to be very minimal.
View attachment 1715437682 View attachment 1715437683 View attachment 1715437684 View attachment 1715437685
I agree it adds up quick. I looked at all the ways to make the hp I wanted to make but when the trickflows finally came out and I could get them for $1800 to my door I hit the easy button.Need to finish talking them apart, do my dimensional checks first, but then I'll clean up there little bit that needs it before they go off for flow and valve job.
A side note here, I'm still ahead of the game vs trick flows, but for anyone who doesn't plan to run them out of the box, the deal is much closer than the sale price would indicate.
Shipping both ways to PRH, valve job, valve seals, and the b3 kit, all of which should be unneeded with the TF heads, all of it adds up.
How big of a cam are you planning to run Turbo.
Now that's the question isn't it.
For the sake of getting things running for the spring (I'm installing a pro flo 4 and and all new fuel system as well this winter) I'm going to keep the Comp 305H that's currently in the car.
I'm sitting on a new set of Johnson mech roller lifters, so next I'm hoping to have pick out a new cam and install it/springs next winter.
The seats of the unported assembled head. Still digging into mine.As best as I can tell, the versions with CNC chambers is only available in a bar head.
Seat pictures attached, someone with more knowledge than me can comment on them. View attachment 1715437725 View attachment 1715437726
I’ll have to check those cam specs out as I’m not familiar with it. I take it the Pro Flow 4 is injection.
Ok since I no longer have access to a ProMaxx Head I went back to my pictures that I posted in my Edelbrock to ProMaxx comparison post. Hard to really tell from pictures but it looks like the ProMaxx heads had a 3 angle valve job compared to a two for Speedmaster. Not sure way they would cut a cost corner there because there is zero labor costs involved in the two. ProMaxx heads also have some cfm gaining attention to detail in the valve seat installation as it looks like the were flapper wheel sanded and cleaned up a lot nicer after being pressed in. Athe shortside was nicely blended instead of stepped. If I were a betting man these will be in the 248-258 cfm area max. The valve job sucks but I’m still sticking with it will flow better than an Edelbrock
What does a stock Edelbrock SBM flow on your bench before you violate it with the burr?
If you polish out those spots in the picture you'll be making the port bigger than it already is. Are you sure it wants to be bigger there?
Not sure about anything yet. Plan is to check the cross section of the clean port with a snap gauge and compare vs the ones with some as cast surface.
I'm smart enough to know what I don't know, so feel free to give me any feedback. I planned mostly a light polish vs any real material removal.
Just keep in mind that cnc ridges won’t bother a thing and may help. When I port my own heads it’s a double flute burr finish on every intake side. I would take a semi rough sanding roll to customers ports because people like smooth.
You have two options as to why you have bald spots in a port.
Tool defection or the casting is big there already.
