That cat ain't little....
But it's a good companion...
You need to reverse the handle on the leveler....
You also have to watch which side you put the crank on when you load the engine so it doesn't hit the bar on the engine hoist when you have it tilted and ready to drop in...
I have one that has just large nuts on each side of the acme threads and just use a ratchet with a 1 1/16" socket to tilt. Then I can use whichever side is more convenient... You may want to delete the handle on that one and just use the large "nuts" also...
