Mad Dart
Nothing to see Here!
Cool almost there!
his arent the best.i will see if he is interested.worked down at devils den last week,installed the atomic efi on one of the oakland raiders cars.it was as easy as advertised to install.it went on a 71 chevelle 454 smog engine,th 350,12 bolt.car was nice excepting the wheels andfloorpans lol.fred and wilma would have been right at home!View attachment Img_130918105128(1).jpgMan that sucks, sorry to hear that man. Hey funny you should mention 73 challenger I bought a set of tail lights and housings at a swap meet for a 73. If he ends up needing them let me know because I have no use for them and they are OE. Hope things work out for you mike, hang in there.
also those aluminum collector gaskets they were 18 bucks.but worth it it blew the paper gaskets out with a quickness...anyonewant to trade or buy that tranny pan?almost forgot the bypass deal sure made the fuelpump quieter!just got to install the gauge and see if it cured the problem...Nice.
**** i put it on with the bolts holding the gasket (like always) except the two on the driver side that the b and m bracket uses tightened it up filled it then watched trans fluid pour out as fast as i poured it in.damn gasket folded into the pan in that damn spot.pulled it rightback off saw that corrected it and filled it again,good thing i had more fluid.hate doing **** twice....Aluminum, collector gaskets, great choice. .Kinda surprised ,on the trans pan. Usually stock works,applied correctly.
