Got old timers.
Now read 973.
Got old timers.
Now read 973.
hp is for mph but not necessarily et. Bigger ports/valves dont mean they will be fastercurious, wouldn't it be more hp if the et was lower, or are you think'n more bottom end torque?
well, if the car hooks up the only way the car goes slower with more hp is if it's at the expense of bottom end torque.hp is for mph but not necessarily et. Bigger ports/valves dont mean they will be faster
Because I don't know what I'm doing, it's in 2 videos.... LOL ! I forgot to mention, always wear safety glasses! I will post more pictures on the intake side of the porting later.
Ok, somebody needs to help me, can't upload the videos.. ale:
I tried the URL from you tube, tried straight from the camera, no luck...
Can anyone help?? If you go to utube and type in DSCN02721 you will get my 1st video. the 2nd video is DSCN02731.
If someone can post them for me, in order, I'd appreciate it......
went down to the storage shed and the car is still there!! lol. Brought the dual quad set up down there, get a moment in the next few days, I'll throw it on.I checked the gasket match on the dual quad intake, and removed a couple of "obvious" burrs from the casting. Ready to bolt it on now
My seat of the pants meter agree's with you as well. For fun I slapped a BB tq on a small block and the difference was noticeable.^^^ general consensus is I over carb my motors. I disagree, and the ET slip agrees with me.
funny you posted that because I ate tacosNuh huh. It could be at the expense of you eatin too many tacos. Fatty.
the intake list continues on this 318.Love how ugly the rtv usually looks when you pull an intake manifold.
Takes a bit to seal, you usually find out the hole ya made in the end was too small ...and so..you go back over it again 2 more times ...before you decide it's too far in and add a 4th..lol ...oh, and then then those corners need one more squirt. LoL
Still got the cork n pin.
Is there a reason you are going with the weiand as opposed to a edelbrock performer?the intake list continues on this 318.
- '73 cast 340 intake
- Holley Street Dominator
- Weiand Action Plus
- Upcoming - Offenhauser dual quad
Ha! I love me some good tacos.
I just pulled the Weiand off for the offenhauser that that's going on. I did a intake test on the factory cast vs holley SD vs Action Plus to see what it would do on a very mild 318. Now the dual quad gets a shot.Is there a reason you are going with the weiand as opposed to a edelbrock performer?
I almost went with that also but then read that the edelbrock ports were closer to my 318 tiny intake ports. I think it was because it was easier for me to use the felpro 1243 gaskets that were 2.08x 1.05.
I was worried about my small ports until I read this thread, now i have work to do lol and want the better of the 2 intakes.
I did gasket match the intake but did not remove the heads and do those ( I wanted to but was worried I might screw them up) now I know What to do and its no big deal by the looks of it.
That's cool for sure. But I rather "like factory dual quads", all under the hood.Like JPar, I wanna see a couple of carbs sticking thru the hood!!!!
Me too man, my wyfe is meskin and makes the best tAcOs this side of Tijuana slewHa! I love me some good tacos.
I personally like the Action plus better than the edelbrock performer. Just my opinion. Don't worry about the small ports. I've run factory cast intakes which have the 340/360 port on 318 heads all the time. Not a big deal. Perfect port match is ideal, of course. But just for the say'n, the 340 factory cast intake with biggest ports actually gave the best ET, even the the Holley SD had 318 size ports, and the Action Plus is "in between". All 3 intakes were within a .15, though
Nice, thank you!!
I also have a '75 360 sitting in a Winnebago, do you think those heads would be an improvement over the small port/valve '74 318? I plan on doing this home head porting and want the best bang for my bucks. If the 360 is still good that could be an option also but I don't mind running the 318. It's in a '74 power wagon so millage and power is what im looking for.
if the 360 is a good motor, I would probably use it. You'd have more low end torque and power. You may give up a mile or two per gallon... but not if you are pulling.Nice, thank you!!
yes. a guy here got better gas mileage with a V10 than a 5.2 pulling a 10,000 pound trailer around everywhere. Torque adds to gas mileage when the motor is working.My 68 3/4 power wagon with 318, 2 bbl, 4 sp, 4.10 gears and 9.50-16.5 tires pulling a loaded 4 horse trailer got 8 to 10 mpg.
Swapped to a 76 360, 4bbl and gained more pulling power and 2 mpg.
55 mph is my max speed for hauling loaded with animals on the hiway.
