TrailBeast
AKA Mopars4us on Youtube
Well, it's not really a trans leak per se.
It comes out of my speedometer cable behind the dash
This is caused by having a good seal of the cable to gear housing, but a bad seal around the speedo gear so fluid works it's way up the drive cable housing.
It doesn't drip yet while driving, but I noticed it the other day when I pulled the cluster out and a little trans fluid dripped out of the cable.
I even still have the seals in my toolbox from when I did this stuff for a living.
This was just an FYI in case you have an oil spot on your pants leg that you cant figure out where it came from.
