dartman59
1971 Dart /6. About 85000 miles. Three sp manual transmission. I am having a hard time diagnosing what seems to be a sick or injured engine. It all started about 3-4 weeks ago. This car is my daily driver this time of year. It has always run nice and cool, no matter what the weather or the load. Never had an overheating problem; in fact, in the wintertime I complain my heater doesn't blow hot enough air (new core, so no problem there...).
Recently, on a 15 mile ride, I noticed after about 5 miles that my [ame="http://www.amazon.com/s/keywords=temperature%20sensor&index=garden"]temperature gauge[/ame] was up around 1/3-1/2. Not quite to the half-way mark (non-rally, stock dash & gauge). After about 10 miles (cruising at 65-70 on the interstate), I started smelling coolant. After 15 miles and when I pulled into my driveway, I had pretty much lost all my coolant through the puke bucket, which doesn't have a cap on it. Coolant all over the engine compartment. Big mess.
This car has NEVER overheated before. Why this all of a sudden? So, I filled up the radiator (with plain water), fired her up and let it sit until the thermostat had opening and I could see that things were flowing, put the radiator cap on, and took her for a spin. Everything was fine, temperature gauge at the 1/8-1/4 mark as per usual, and after about 5 miles the gauge crept up to 1/3-1/2 mark, and I headed back to the house, where I found that I had again lost my coolant through the puke bucket. When I stopped the car I could hear a humming noise (engine still running) and when I popped my hood the puke bucket was boiling over and the radiator cap was doing the humming and vibrating, as coolant was boiling out of the radiator and into the puke can.
The important thing here, to me, is this overheating was a sudden occurrence. Never happened before, so why now? Since then I have done the following:
- New water pump.
- Flushed the cooling system extensively.
- New thermostat.
- New radiator cap.
Guess what? Still is overheating, and not running particularly well. I noticed at one point that the vacuum hose on my Holley 1920 carb that controls the air cleaner flapper had come off the fitting, and that fitting was just sucking air all the time. I thought, "Ah ha! I'm running lean! That's my problem!" So, I fixed that, but it made no difference. In fact, the engine runs like crap when I close off that vacuum port. The rpms drop significantly and I have to boost the throttle to keep it running.
Which makes me wonder if I have a valve-related problem? Could my valve timing be off? Would that cause symptoms of overheating that came on suddenly?
I know this is a long rambling post, but I'm confused and a little bummed out about this. I feel like there is something going on with this engine that I cannot understand, and I don't like that feeling.
Any ideas are appreciated!!
Thanks!
- New water pump.
- New thermostat.
- New radiator cap.
Thanks!
