On the choke are you turning the key on, pushing the gas pedal to the floor once, then cranking it?
Drop the tank, you have a lot of crap in the tank and lines.
Take the tank to a radiator shop and have it boiled out.
Disconnect the fuel line and get a small aquarium pump and circulate white vinager thru the fuel lines.
YesSo this is better than ordering a new tank with a new sending unit? My gas guage doesn't work either.
What's the story about the old gas? How long has it been there? How full the tank? Through what sort of weather cycles?Could be old gas
PS. if you post the mechanical timing vs rpm we should be able to tell which advance mechanism is in there and what is probably going on there.
I highly doubt it too. I would be willing to bet it actually needs 2-3 steps down. Carbs are always severely over jetted for liability concerns. You won’t know exactly where it is until you install air fuel gauge. I used to rely on reading plugs. But, Ive found the air : fuel ratio can be very rich even when the plugs don’t necessarily show that. I thought my car was running very good by upsizing the jets from where it was jetted when it was shipped. I found after a gauge it actually needed 3 steps down on jets. Makes a lot more power now.Initial, this is a mild 340 with J heads and small port Weiand 8007 Action Plus spreadbore. I haven't driven the car much in the last 10 years so I'm gonna run this gas out and do some tuning before I speculate too much. I will report back how it's running. I'd be surprised if it needed larger jets.
You don’t necessarily need a choke. I live in a colder region. My car never had a manual or electric choke. All you have to do is pump the pedal 5 or 6 times if car hasn’t run in a couple days. It will fire right up. You just need to feather the throttle for 10-20 seconds until the engine builds a small amount of heat. When you restart the car after it being warm. It’s not needed there either. Just turn the key it will fire up with no throttle input needed. I actually removed my choke valve. So it doesn’t accidentally close while running the car. I put 5k miles on my engine never having a choke. Some engines won’t start without one. These carbs self prime themselves when you pump the throttle. It squirts gas, not necessarily needing a choke. .Yes, that’s been my procedure thus far. I’ve been told to give it a couple pumps before I turn the key on. Then turn the key on and give it one pump to set the choke. Your thoughts?
Do you need a choke, it depends....You don’t necessarily need a choke. I live in a colder region. My car never had a manual or electric choke. All you have to do is pump the pedal 6 or 7 times if car hasn’t run in a couple days. It will fire right up. You just need to feather the throttle for 10-20 seconds until the engine builds a small amount of heat. When you restart the car after it being warm. It’s not needed there either. Just turn the key it will fire up with no throttle input needed. I actually removed my choke valve. So it doesn’t accidentally close while running the car. I put 5k mines on my engine never using a choke.
That’s what I’m talking about. Lol ! Sure, an electric choke is remotely necessary if you want to walk away from the car immediately after it fires. Otherwise, it’s not. With a manual choke, you don’t have the convenience of immediately walking away from the vehicle when it initially fires, either.Do you need a choke, it depends....
I had the 625 street demon on my truck at 0 deg F start on the first crank, and jump up on high-speed idle.
Push the petal once, roll the engine and fire up to an idle speed, that I could walk back in the house until it warmed up. Way nicer jumping in a warm truck.
Did this several times, when my wife would steal my Jeep to get to work in deep snow.
sounds like the rebuilder F'd up. I like that Street Demon design myself. I feel the TQ was the leading edge in carburetor design when it was introduced.sounds like the O-rings, or a needle seat, or terrible float setting, but I'm betting the o-rings
I agree with you. My carb didn’t come with electric and I didn’t necessarily want to mount a manual choke to my fully restored, full original look dash. I initially tried, but regardless of how it was routed. The cable would always bind. So, I threw the brand new cable in the trash. lol ! The car starts as easy as any other, without one.With a manual cable choke you have to play with them, have one on my old 48 willys jeep.
It also will start first crank after sitting all winter in storage.
Pump the gas once, pull the choke and it idles, then feather the choke until warm.
