Duane
Here you go.Duane. post the picture of your crossover for the head oiling.
Just some friendly advice. Keep in mind that these are full on race modifications. More better oiling does not hurt but we also do not want to ruin a perfectly good block. Take some time and study the block and make sure you understand the circulation of the oiling.Thanks for the information. It seemed to me if I was going through all this to make sure the oiling was better, I may as well have full time oil up top also. Just fyi this is a street/strip pump gas 408 build.
Also are you sure you understand what you need to do with the cam bearings to do the jumper tube mod?Thanks for the information. It seemed to me if I was going through all this to make sure the oiling was better, I may as well have full time oil up top also. Just fyi this is a street/strip pump gas 408 build.
Jada please remember that I ran my crossover line from the passenger side to the drivers side differently because I have an X block that can front oil so I am using that feature. The main galley will be fed from both ends and the galley is plugged at the front as well so there should not be a velocity problem with two opposing oil feeds. Just an FYI. This is the Charles Sanborn method.Duane. post the picture of your crossover for the head oiling.
Pretty big chamfers at the top of those lifter bores, I heard those type bores leak huge.View attachment 1715251031
Beneath the set screw, I drilled a small hole in to the main oil galley to feed the passage full time. To feed the left side you would replace the set screw with a fitting and put a line from it to the left side passage.
Be very careful when drilling into the main galley to line up correctly or you will hit the water jacket.
That's is correct. Make sure your engine machinist or whoever is installing the cam bearings understand that as well.The way I read it was to drill 1/8" holes in the cam bearings and rotate the bearings so these new holes line up, thus blocking off the stock holes feeding the heads.
I ran a grooved comp cam in my last motor to get full time oiling that way, and I lost the spread on the 2&4 main bearings after 40 runs.is there a problem with getting full time rocker oiling with a groove in the 2 and 4 cam journal like Crane and others did? and my flat solid lifter 340 has been going since 1995 with no full time oiling (Hughes said he did testing and at speed the cam spinning fast gives like a steady flow) and I blocked oil to the drivers side with a plug in the front driver side passage. no crossover tube, enlarging passages at filter and from cam to mains per old Dick Landy
.Pretty big chamfers at the top of those lifter bores, I heard those type bores leak huge.
Allow me to refresh your memory.leakage at cam bearing? I guess it is controlled by the tight cam to bearing clearance. A mistake many make, that restricts oil with a stock block, where oil up to the rockers goes up around the 2 and 4 .450" head bolt, is using a .500" stud
The type of leakage that you are talking about is the type where the oil band may uncover the large oil feed passage in the lifter bore and drop the main oil pressure. This would as you say vary with the type or design of the lifter. That is not what I am talking about.the large chamfer leak problem depends on type of lifter and amount of cam lift, may be a problem, maybe not
Implying what ???I also measure every lifter bore diameter
.I also measure every lifter bore diameter
I know lol, I wanted him to say it instead of making blank statements with no follow up dialog. But apparently he does that..
I'm assuming this is checking for excessive wear or lifters slop?
.I know lol, I wanted him to say it instead of making blank statements with no follow up dialog. But apparently he does that.
FWIW, for a data point on the chamfers leaking: My son's 340 was a virgin block, with the chamfers, and the lifter bores were unworn. (A couple were so tight that we had to get Crane to send us a few extra HFT lifters with OD on the small end of the range, so we could fit them in some of those tight lifter bores.)Those blocks with the large chamfer even with a stock lifter have less precision surface contact because the large chamfer has machined it away. This leaves less surface contact and allows the oil to leak by easier. IMHO those blocks leak more.
