You really have. And the color is gorgeous! Looks like a heavy flaked B58)Love the color. You've come a long way in a short time.
I got all of my adjustable shocks mocked up (and no they are not mounted upside down, that is the way ProComp says to mount them) and I also welded up some upper shock mounts, because the factory mounts were a little too high, because I ended up lifting the suspension about 6" instead of 4" :snakeman:. They are a little ugly, but plenty strong.
I also fabricated some lift blocks on the bridgeport at work to help level it out. So it now sits 2" taller than the previous pics. I think sway bars will be needed. :-D
I will have more pics in the next couple of days.
I hate to be the bearer of bad news, but you should mount shocks in double shear not single shear. Those top mounts for the front shocks will snap off. This is critical with heavy vehicles. Just a thought. Brackets are readily available pre-made.
http://http://www.ballisticfabrication.com/Coilover-Shock-Tabs_c_197.html
Also: Does the rear spacer have a through bolt? You might check driveline angle and machine a couple of degrees of angle in the top spacer to keep the driveshaft angle correct.
Thanks
Damn, you're a one man army. Nice progress in a small amout of time. Looking forward to the finished prduct.
So I started to pull the steering column for paint and I noticed the lower bearing was seized up and the shaft was just spinning in the ceramic bearing inner race. I was bored tonight at work and made an aluminum housing with a sealed bearing on the lathe. Should be very strong and is held in place with a snap ring and has stainless steel hardware. What do you think?
Looking great Badart. Just a question, are you going to run without the inner fenders?
:thumbup::thumbup:, Dang Badart!! you sure have got allot dun this winter :headbang:
You have the stance down pat bud! And I am enjoying all the cool fab work you are doing.
I have got to say I like your color and the price on the wheels :thumbup: man that was a buy. You do great work and I was so surprised to see paint going on as I went through this thread to get updated on your progress
